1992 EH2 EG Hatch Complete PART OUT
Old Jun 7, 2014 | 11:14 AM
pelayo114's Avatar
Default 1992 EH2 EG Hatch Complete PART OUT
COMPLETE PART OUT. ASK FOR ANYTHING. I have started to remove parts for the car as seen in the pictures.
Parting out my 1992 EH2 VX Hatchback.
I still have a majority of the car. Ask for a specific part if its not listed and I will get back to you ASAP.
Car also has Viper 3303 Alarm system with tilt sensor, glass break sensor, motion sensor and proximity sensor. I still have the original box with all original remotes. Offer.
Reason for Part out: Purchased an AP2.
WILL TRADE ANY PART FOR AP2 PARTS. Let me know what you have.
CALLS WILL NOT BE ANSWERED. Leave a voicemail if you would like a reply. I do not answer blocked or unknown calls.
Text me at: (818) 270-4811
Email me at: pelayo114@gmail.com
or PM me. I sometimes forget to check my threads but PM's and emails go straight to my phone.
Currently has 2000 Prelude Seats on EG Rails. Super comfortable seats. As seen in pictures below. $200
D16Y8 Cylinder Head with only 6000 miles since complete rebuild/resurface. Will include valve cover. Skunk2 adjustable cam gear is optional, Distributor is optional, Intake manifold is optional. $200 for cylinder head with internals only.
Sinko-R Tenzo's 17" with 205/45/17 tires. will need new tires but wheels are in good condition, just dusty in this picture. $250 for all 4
I also have a rear brake disc setup out of a 1995 Integra LS with the LS lower control arms, rear sway bar, polyurethane sway bar bracket bushings, compensator arms, upper control arm, and e-brake lines. $300 for complete swap. Pictures upon request
Koni Yellow/Ground Control Springs with Ground control extended top hats on all 4. Less than 6000 miles on them from new. Spring rates 300F/350R. $900 for this setup. Will not separate. Pictures upon request.
I also have EG trailing arms with drums for sale. Complete with e-brake cables, LCA's, UCA's and compensator arm $60 takes both complete sides.
13" steelies. All 5. is included. $100
EG/EK radiator. Aftermarket. Like New condition. $40
EG Hatch Rear Spoiler, OEM. Off of a teal hatch, silverstar lightbulb and socket. $60
EG hatch/coupe manual door panel handle FREE
H3 6000K HID's including ballasts. $60
Under dash panel Black OEM EG $20
EG Main Relays and 2 other relays $10 each or $5 for smaller ones
TD-80U D16Y8 Distributor with plugs for OBD1 $90
EG Gauge Cluster with Tach, for Automatic. Fully functional $60
TD-68U Distributor $80
Muffler for EG, note is not raspy, sounds deep. $30
EG Coupe/Hatch Passenger side window $40
EG Coupe/Hatch Driver Side window $40
EG LCA's with Strut forks. $40
D16Y8 Crank, Spun rod bearing on CYl#1 FREE (local pickup ONLY)
EG Coupe/Hatch driver side power window regulator with motor $60
EG Upper control arm, Driver side. Brand New with ball joint and bushings $50 each. I also have passenger side also brand new never installed
Pioneer 6x9 3 way speakers. USED. $30 for both
D series upper timing belt cover $10
EG Coupe Taillight, $20 EG Hatch taillight $10(has some damage by lower left inside socket
EG Hatch Lift Support $10
Del Sol bucket seats. Used. Some wear on the driver side left and minimal on passenger side right. from normal car entry and exit. $160
ALL PARTS PRICES ARE OBO!!!!!!!!!!!(unless otherwise stated)
SHIPPING IS NOT INCLUDED!!!!!
PAYPAL FEES ARE NOT INCLUDED!!
S20 Transmission- SOLD
Manual Window Regulator- SOLD
D16Z6 Intake Manifold- Given Away
75 Series Duralast Battery- Given Away
EG Center Console-E-Brake Cover- Given Away
EG Hatch Rear Strut Covers- SOLD (burnoutboy)
EG Complete Center Console- SOLD (burnoutboy)
EG VX Rear Diffuser with Hardware- SOLD (burnoutboy)
P28 Chipped and Tuned ECU- SOLD (local friend)
Front Strut Bar- SOLD (local friend)
Rear Strut Bar- SOLD (local friend)
D16Y8 VTEC Solenoid- SOLD(local friend)
Old Jun 7, 2014 | 12:11 PM
bks84's Avatar
Loved
Default Re: 1992 EH2 EG Hatch Complete PART OUT
Interested in the following
d series upper timinng belt cover
eg hatch tail lights (all four pieces)
eg hatch/coupe front sidemarkers
eg black steering wheel and air bag.
shipped price to 64050
thanks
Old Jun 7, 2014 | 02:03 PM
99kleansi's Avatar
Could you ship only the strut forks?
Also interested in headlight housings and many moulding pieces..ie windshield left and right moulding roof rail moldings and door exterior moldings
Old Jun 8, 2014 | 03:49 AM
driguy's Avatar
PM'd you about the rear strut covers, some main relays and the hatch lift support.
Old Jun 8, 2014 | 08:48 AM
jdmsiR20's Avatar
Need that Purge Cut Solenoid (attached to intake manifold, on back side).
Also a shift boot, and the moonroof-dimmer-blank switches if they're available.
PM me or text 415-525-6two64.
Thanks!
Old Jun 8, 2014 | 01:14 PM
e0325's Avatar
Pm sent
Old Jun 9, 2014 | 12:30 PM
DA BOSS's Avatar
How good is the bezel that goes around the climate control?? Can u take some close-ups... I'd be interested if you'll pull it.
Old Jun 9, 2014 | 01:14 PM
209lsr_ly's Avatar
ill pick up them del sol seats but too far
free bump tho glws
Old Jun 10, 2014 | 09:11 PM
pelayo114's Avatar
All PM's replied to.
@209lsr_ly thanks for the bump
All else, I will try to get PM's out tonight.
Old Jun 15, 2014 | 08:58 PM
rspecturbo's Avatar
if the clips on the driver side glass is fine how much for it and the rear hatch glass weatherstrip shipped to 76013
Old Jun 21, 2014 | 11:08 AM
burnoutboy's Avatar
The Credible Hulk
Awesome seller, shipped me the rear strut covers, the VX diffuser, and the lower center console. EVEN INCLUDED ALL HARDWARE! Great seller, would buy from again with no hesitation!
Old Jul 6, 2014 | 03:47 PM
pelayo114's Avatar
Door clips are slightly damaged
Rear weatherstrip is dried out.
Taking all and any requests. I have been busy lately with school and work. Things are slowing down so I can usually ship items within a few days. Bigger items such as the carpet are on hold. Only due to the fact that I would have nowhere to store the other items that are currently in the vehicle. Once I have either sold a majority of those items or have a new storage place those items can be sold.
Absolutely NO CALLS will be answered. Texting or email communication is preferred due to my work schedule.
Old Jul 6, 2014 | 03:49 PM
pelayo114's Avatar
I also have a black arm rest e brake cover. A 10" bazooka speaker with tube and amp. All as one kit and controller. 5 speed gauge cluster with tach.
Old Jul 6, 2014 | 09:16 PM
Throttle037's Avatar
Need carpet & Door Sills. PM me whatcha want for them
Old Jul 6, 2014 | 09:20 PM
pelayo114's Avatar
Those items are on hold until more items sell or I find a new place to store the items currently in the car.
Old Jul 7, 2014 | 02:27 AM
underrated's Avatar
PM sent
Old Jul 7, 2014 | 09:11 PM
pelayo114's Avatar
Originally Posted by underrated
PM sent
Old Jul 8, 2014 | 11:25 AM
BiggieBert's Avatar
Loved
Community Favorite
Do you have driver side power window switch? I noticed the passenger side, but not the driver.
Old Jul 11, 2014 | 09:24 AM
pelayo114's Avatar
Old Jul 11, 2014 | 09:57 AM
Lucid_Dream's Avatar
Im intested in:
Gauge cluster with tach. (Will the auto cluster work on a manual? Also i thought i read that you have another cluster too with is a manual with tach, correct or no?
Also the integra rear disc brake conversion.
Im in SC 29650 thanks.
Old Jul 13, 2014 | 09:12 AM
pelayo114's Avatar
Thanks for the interest in the items guys. I will do my best to remove items and ship them in a timely manner.
Old Jul 26, 2014 | 09:15 AM
pelayo114's Avatar
PM's replied to.
Make some offers. Local pickup is preferred for all non-bulk items
Old Sep 16, 2014 | 12:44 PM
pelayo114's Avatar
"Long time no bump" bump.
Old Sep 16, 2014 | 08:08 PM
99civ's Avatar
PM me on price for cabin harness. Basically everything from the firewall plug and back. Thanks.
Old Oct 18, 2014 | 05:43 PM
94CivicHatchGSR's Avatar
Condition on the 2 doors?
I'm not far and can make the drive if the price is right. Please clean off doors and take pic at angle so I can see if they are straight or wavy.
I don't need glass or weatherstrip...just the doors itself..
