Bad clutch safety switch?
Old Jun 7, 2014 | 06:57 AM
riverman223's Avatar
Default Bad clutch safety switch?
If i need to " double pump" my clutch on my 1994 Honda Accord to start it, then is the simple answer is to replace the clutch safety switch? Could it be the wiring to the switch?
Old Jun 7, 2014 | 02:33 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Bad clutch safety switch?
Check the switch. It may be loose, out of adjustment, sticking, or simply failing.
Old Jun 7, 2014 | 03:42 PM
holmesnmanny's Avatar
disconnect the connector and stick a paperclip in there, keeping in mind you are disabling a key safety feature for the time being so be safe starting the car make sure its always in neutral, and see if you dont need to do that anymore
brakedrum
Jul 2, 2025 10:36 AM
boost and bass
May 26, 2012 10:07 AM
John 07
Nov 10, 2008 05:30 AM
