wiring issues jdm b18c
Old Jun 6, 2014 | 09:44 AM
rich13611's Avatar
Default wiring issues jdm b18c
I have a jdm b18c motor with a manual transmission I put it in a 2000 civic ek Ej8 it had an automatic transmission I used the harness from the old motor It was a d series have a p72 ecu manual and there's one to many plugs at the ecu plz help
Old Jun 6, 2014 | 09:49 AM
grumblemarc's Avatar
The Grumpiest
Default Re: wiring issues jdm b18c
Stop saying "plz help". It's annoying.
As I understand it, because it was an automatic, there are going to be extra plugs, for the automatic that isn't there any more. What exactly is the issue? Did you install it or did someone else?
Old Jun 6, 2014 | 10:05 AM
rich13611's Avatar
Ok I'll stop and yes some else did
Old Jun 6, 2014 | 10:06 AM
rich13611's Avatar
I put the motor in someone else did the harness
Old Jun 6, 2014 | 10:08 AM
The Grumpiest
I asked you TWO questions.
Old Jun 6, 2014 | 10:13 AM
rich13611's Avatar
Will it work like that do i leave it Unpluged?
Old Jun 6, 2014 | 10:15 AM
The Grumpiest
Have you not even tried to start it up?
Old Jun 6, 2014 | 10:17 AM
rich13611's Avatar
Will it even start?
Old Jun 6, 2014 | 10:18 AM
rich13611's Avatar
I did with the old auto ecu
Old Jun 6, 2014 | 10:19 AM
rich13611's Avatar
Starts rite up
Old Jun 6, 2014 | 10:22 AM
The Grumpiest
If it doesn't throw any codes and runs then what's the issue?
Old Jun 6, 2014 | 10:28 AM
rich13611's Avatar
I didn't try it with the p72 ecu yet because of that plug but i will and scan it and see what codes come up what do u think?
Old Jun 6, 2014 | 10:38 AM
rich13611's Avatar
Thank you for your time
Old Jun 6, 2014 | 01:01 PM
HondaPartsHero's Avatar
Technical Hero
Try it with the P72 if you've already converted to 5 speed. You'll have to wire up a few things IACV, VTEC, knock, IAB.
Old Jun 6, 2014 | 01:20 PM
rich13611's Avatar
Just tried it with the p72 cranks but doesn't fire tried it with old ecu and it starts
Old Jun 6, 2014 | 01:34 PM
The Grumpiest
Is the P72 in working condition? Any ECU should theoretically be able to start and run that engine unless you have this one chipped and the basemap is bunk.
Old Jun 6, 2014 | 01:50 PM
edwinie26's Avatar
I'm assuming you have an obd2 chassis
And you are using an obd1 ecu
Purchase a obd1 to obd2 adapter.
Or purchase obd2 ecu if you go obd2
Make sure to wire in
Knock
Crank
Make sure of your grounds
Your timing
And your sparkplugs order
Vtec wires and iab
Old Jun 6, 2014 | 02:02 PM
rich13611's Avatar
Ecu is a p72 its ODBII. Im thinking the issue is with me changing auto to manual.
Old Jun 6, 2014 | 02:07 PM
rich13611's Avatar
Need to figure out how to get my harness that is wired for a P2P into my P72.
Old Jun 6, 2014 | 02:32 PM
The Grumpiest
Knock
Crank
Your timing
Vtec wires and iab
Are you saying you did these things?
Old Jun 6, 2014 | 02:59 PM
edwinie26's Avatar
Yes but mine was obd1 auto to manual conversion.
Don't know how differnt the chassis is just want to put some info on what I delt with.
He said he was missing a plug for ecu so I thought wrong ecu.
Car won't start if ground near the thermostat housing isn't making good contact. . Also the swap had the sparkplugs on wrong found that out after a couple cranks...don't bash me just trying to put some insight.
Op can you take a picture if what extra plug you are talking about and what is the complete number on your p72? P72-xxx?
Also like stated above check for codes, and since it worked with another ecu try a p72 from a friend. you might have a bad one.
Old Jun 6, 2014 | 03:04 PM
The Grumpiest
2000 Civics aren't OBD1.
Old Jun 6, 2014 | 03:11 PM
tony_2018's Avatar
Fish Twig
You civic is an obd2b, what yr ecu is the p72? There is no wrong way to hook up the ground wire on the thermostat housing. I'll be damn if its not the ground wire.
Old Jun 6, 2014 | 03:12 PM
rich13611's Avatar
i know it is
Old Jun 6, 2014 | 03:13 PM
tony_2018's Avatar
Fish Twig
You know it is what?
