Turn Signal gone Bizerk
My left turn signal goes on only when I don't press on the brake, but when I press on the brake my turn signal comes back on. It's only with the left turn signal not the right. This has never happened before and I have never messed with any wiring. WTF is going on. Can anyone help with this problem or has anyone experienced this problem before. Any info. on this would be appreciated. THANX
Check your battery connection if you haven't. Something like that happened to me and it was a loose and corroded wire on the battery.
It also could be a bad ground somewhere.
Hmm.. So what your're saying is that you step on the Brake Pedal and the Left Turn Signal comes on. I'm not too sure about Civics but, if the bulb in the Turn Signal is a double filament bulb, I'd check that first. If the filament is burn out, I'd just replace the bulb. Weird things happen when bulbs go out..
elecktro
Nov 11, 2011 01:52 PM
ridgeline08
May 29, 2011 10:38 AM
veilsides2000
Oct 18, 2004 07:49 AM
Fuster_Cluck
Honda Motorcycles
Jan 30, 2004 06:08 PM
