Car Randomly dies and misfires
Old Jun 4, 2014 | 12:34 PM
KidRuthless's Avatar
Icon2 Car Randomly dies and misfires
Still having a occurring problem its been happening for almost two years. Ill be driving and my car will randomly die, after time it always starts. It also misfires while steadily holding the gas. This problems persists once or twice every 3 or four months.
1997 Dx HB 1998 GSR.
Old Jun 4, 2014 | 12:36 PM
Default Re: Car Randomly dies and misfires
I changed my ECU, Distributor (Used), Main Relay.
If it were the ignition switch, coil, or Dizzy wouldn't my car not turn back on if one of these failed?
Old Jun 5, 2014 | 09:45 AM
turbomaniac's Avatar
obd codes?
Old Jun 5, 2014 | 08:21 PM
Originally Posted by turbomaniac
obd codes?
No codes. Only codes stored is secondary 02, vtec solenoid (fixed),cpk sensor (fixed).
Old Jun 5, 2014 | 09:11 PM
there is a test you can do in order to figure if the problem is a damaged 02 sensor.
simply unplug the sensor. if the problem fixed, than is the 02 that causes the problem.
If not, unplug the negative from battery for at least 20 seconds (the ecu will be reset) and see if the problem still exists
E M Wynne
Jul 13, 2017 09:26 AM
Brandoff
Nov 19, 2008 04:29 AM
_RedRiceR_
22
Jul 18, 2006 05:54 PM
Guru Designs
Jul 23, 2004 03:01 PM
PiYoImuT
Sep 16, 2002 04:21 AM
