Compatible distributor for 99-00 Civic Si?
Old Jun 4, 2014 | 06:50 AM
$amGD3's Avatar
Swaggylicious
Default Compatible distributor for 99-00 Civic Si?
I'm running an external CDI ignition setup in my vehicle that bypasses the internal ICM and coil.
Unfortunately, the CYP sensor in my distributor housing has failed and I'm seeking a new one.
What model vehicles are compatible? I know that the 97-01 GSR is the same as my 99-00 Civic Si but these two are never in the junk yards.
Are there any other vehicles that will work? OBD2b vtec
Can i pull one from an OBD2 LS Integra or even a CRV?
Or am I better off buying a new $60 ebay distributor since I wont be using the coil, icm, rotor or cap
Old Jun 4, 2014 | 07:56 AM
ElectronBlue00's Avatar
Default Re: Compatible distributor for 99-00 Civic Si?
https://honda-tech.com/forums/tech-misc-15/ls-dizzy-b16-question-answered-2858749/
Old Jun 4, 2014 | 08:03 AM
So for reference, since the b18/b20 use the same distributor, you would have to modify the distributor for it to mount properly. The car will run with an LS or b20 distributor.
Here's a good list of the distributors and motors they work on. NOTE: This list only provides DIRECT FITMENTS, and will not list distributors that will work with modification.
[TD-01] Civic/CRX DPFI 1988-1991
[TD-02] Civic/CRX MPFI 1988-1991
[TD-03] OBD0 DOHC ZC Civic/CRX 1988-1991
[TD-22] OBD0 B16 Civic/CRX/XSi 1988-1991
[TD-23] OBD0 B18a Integra 1990-1991
[TD-31] Accord 1990-1991
[TD-41] Civic D15b Non-VTEC 1992-1995
[TD-42] d16z6/d15b VTEC 1992-1995
[TD-43] OBD1 DOHC ZC 1992-1995
[TD-44] OBD1 B16/GSR/ITR VTEC 1992-1995
[TD-46] OBD1 b18a/LS/B20/CRV 1992-1995
[TD-52] Accord 1992-1993
[TD-55] OBD1 b18a/LS/B20/CRV 1992-1995
[TD-60] Prelude H22a 1992-1996 JDM
[TD-63] OBD2 99-00 OBD2 Civic D-Series Non-VTEC
[TD-68] OBD1 B16/GSR/ITR VTEC 1992-1995
[TD-73] OBD2 99-00 OBD2 Civic D-Series Non-VTEC
[TD-84] OBD2 B16/GSR/ITR VTEC 1996-2001
[TD-89U] Prelude H22a 1997-2001 JDM
I'm not sure if you've trouble shooted the CYP issue, or not.
From RonJ: Check the CYP sensor resistance - spec is 350-700 Ohms. Also check the two CYP wires for a short or open
(Reference: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/code-9-cylinder-position-sensor-2904710/)
Old Jun 4, 2014 | 09:42 AM
$amGD3's Avatar
Swaggylicious
Yep i've done the troubleshoot
Looks like I'm pretty much limited to a b16/gsr distributor unless I want to run a janky leaking setup
Old Jun 4, 2014 | 10:01 AM
kyden's Avatar
obd2 b16/gsr/type r. But remember the caps are different between b16 and gsr/type r distributors.
Old Jun 4, 2014 | 10:02 AM
Unfortunately so .
Unless you're comfortable with rebuilding. I believe you may be able to use internals from an LS/B20 distributor.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-rebuild-your-distributer-using-different-model-dizzy-2441044/
Edit: The only thing i'm not able to verify is if the sensors/internals and or CYP will be a direct bolt up into the B16 distributor. If someone can confirm... that would be great!
Old Jun 4, 2014 | 06:38 PM
carlos8's Avatar
SI 99-00 = TD-81
GS-R = TD-86/87
Same harness and bolt pattern, different cap and rotor.
Old Jun 5, 2014 | 04:58 PM
94EG8's Avatar
Seagull Management
You can use the CKP/CYP/TDC sensors from any OBD2 B-series distributor (except '99 - '01 CR-V as they don't have quite the same pins, even then if you jam them in there they will work) Even a '96 - '98 D-series distributor has the same sensors (Except HX)
Old Jun 6, 2014 | 02:20 AM
HondaPartsHero's Avatar
Technical Hero
You could also use an OBD1 DOHC VTEC distributor with an adapter harness from a Del Sol VTEC or 92-95 GSR.
Old Jun 6, 2014 | 12:10 PM
Great info here!!
MrMug3n
May 19, 2008 08:58 AM
Jdmglenn
Dec 17, 2007 09:11 AM
BoostedJeff
Oct 22, 2004 12:20 PM
93VTEChatch
Sep 25, 2003 11:07 PM
