96 accord wont start
Old Jun 3, 2014 | 05:58 PM
wrlundberg's Avatar
Default 96 accord wont start
I have a 96 honda accord 2.2 vtec. My daughter was driving and it was running fine when it just died. I have checked all I could think of. Its in time with a fairly new timing belt. Its getting spark. And its getting fuel. I checked the compression and every cylinder is 120 dry and 170 wet. The engine light comes on when I turn on the ignition then goes out after 2-3 seconds. The car seemed to be running fine until I aquired this problem. I seem to be baffled. I am not an expert mechanic but I have worked on many cars and am fairly good at trouble shooting. Oh and I put a scanner on it and got a 9-20 code I think it said something about power supply. Thanks for any insight or recommendations.
Old Jun 3, 2014 | 06:25 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 96 accord wont start
You put a scanner and got a code 9-20? Or codes 9 and 20? Which would still be weird being that OBDII has P**** codes. But OBDI code 9 is Crank sensor, and 20 is ELD.
Cranks sensor issue would cause a no start. If she drove through some puddles or junk the Cranks sensor may just have crud on it, or the wiring may have been damaged or the connection come loose.
On a '96/'97 that Sensor is ~$100 aftermarket, ~$300 from Honda. So make sure it is good before throwing parts at it. Check the connectors and for any ferrous material built up the magnetic pickups.
Old Jun 4, 2014 | 02:56 AM
wrlundberg's Avatar
Ty I will try that tonight
Old Jun 4, 2014 | 04:05 AM
Fitz Williams's Avatar
10 Year Member
I thought only OBDII cars used a crank sensor, and on OBDI the sensor was in the distributor. But again, if it is a 96, then it should e OBDII and the codes would be different. Right?
Old Jun 4, 2014 | 12:14 PM
drive junk's Avatar
I HAVE IDENTICAL PROBLEM MY SCANNER FOUND NO CODE HOW DO I CHECK ECM
Aaron Tanner
Oct 29, 2015 06:26 AM
C4AcuraDC2
May 13, 2015 09:55 PM
AccordChris96
Jun 22, 2013 11:47 AM
partialresponse
May 20, 2010 02:08 PM
chokinvicts
Jan 10, 2004 07:17 AM
