Honda CR-V & Element 2WD & 4WD Element & CR-V
engine stall problem
Old Jun 3, 2014 | 01:18 PM
Kire118's Avatar
Default engine stall problem
i have a 04 crv with the K24 motor and manual tranny. the motor has the tendency of stalling when i take my foot off the throttle and disengage the clutch when coming to a stop. the rpm would drop below idle and eventually die. when i try to restart it, the motor would crank but would not fire up unless i open up the throttle. this happens mainly during the first 10-20 minutes of driving. after the motor has warmed up for awhile, the stalling ceases, although i do notice the rpm occasionally try to dip below idle but would catch itself and remain running. also, my CEL is on and the codes indicate misfires on all cylinders. anyone have had a similar problem in the past and can shed some light as to what the problem may be?
Mr.Galloway
Oct 7, 2014 03:18 PM
tribalbreak
Aug 22, 2008 06:20 PM
ev_jonny
Jul 8, 2008 09:33 AM
