F23a or F20b
Old Jun 2, 2014 | 04:30 PM
PreludeRacer023's Avatar
Default F23a or F20b
I have a 95 prelude, ive found a f23 single cam for cheap....its just to have it driving. Will it bolt up to the mounts? also what about the F20 ive also found a cheaper one of those. I have a p12 and p13 ecu, im pretty sure the p12 would run the f20, but just curious. Ive swapped h series motors, but wondering about the f23 and f20 as far as mounts go, any help is appreciated thanks.
Old Jun 3, 2014 | 02:32 PM
preludeNApower's Avatar
Default Re: F23a or F20b
On both of those engines you can reuse your original prelude mounts. I know the f20b has a different drivers side mount.
Old Jun 3, 2014 | 02:35 PM
I'm running an f20b on a p13, but with h22 intake manifold and injectors.
Old Jun 3, 2014 | 04:28 PM
HiProfile's Avatar
It's really a toss-up, the F23A has more torque but is obd2. You could use a 94-95 Accord EX ecu for the F22B1, it would be pretty close. The F20A could potentially run H23 & F22A ecu's also, you just need the corresponding injectors. The downside is both probably have lower redlines than the F20A wants.
jakeiscool
Aug 10, 2021 09:11 AM
helldriver88
Jun 29, 2009 02:59 PM
shanesaccord2
Jul 15, 2008 07:11 PM
BlueDemonAccord
Apr 10, 2004 08:45 PM
juicedh22
Dec 4, 2002 08:31 PM
