HELP!!! what will fit and what won't
i just bought a 88 civic si but it has no tranny so i called my local junkyard and they said that they didn't have a tranny for a crx si but they had one that would fit it. but when i got it home it is out of a 4 door sdn with a 1.5 liter motor will this work and if so do i oreder the cluth,presureplate and throw out bearing and pilot bearing for an 88 si ?
is the trans from an 88 also
they changed the trans... 88 have different spline count than 89-91
but yes it will work and buy a clutch for your same car if the trans is an 88
if the trans is a different year.. you will probably be able to use it but gotta get different clutch combo.
somebody has to know exactly.. hope i helped
ok, the 1.5L trans will bolt up, but will NOT be the same gearing as the Si trans. 89-91 trans all had the same input shaft splines. 88 had different splines, so you may need to change the disk if you didnt get an 88 trans.
