Code 41 still after O2 replacement help!
I have a 92 integra b18a1 swapped into a 93 civic hatch si. Aftermarket header and full exhaust.The guy i bought the car from said the ecu was fine and went with the motor. I got 4 long blinks and 1 quick, so code 41. The code is for the 02 sensor heater. I replaced the 02 sensor with a Bosch sensor, and the code is still there. Im burning oil and it has a sweet smell, idk if that gas. What else could be my problem. The guy extended the wire harness for the 02 sensor with butt connector and 14 g wire, so it couch reach down near the cat. Guy said this needed to be done. Honestly idk if he is running the civic harness or the integra harness. Either way, i tried to clear the code, and still the code is showing.
edit: when you put the new 02 on did you reset the ecu?
I did reset the ecu a couple times, There is 2 white wires, and a gray with white striped and a regular gray wire. Which ones you think, both whites are ground?
If it were me I would trace the wires back to the originals. Take off any tape or wire loom that would other wise cover the wiring. Do one wire at a time, so as to not get confused. Can you take a pic of the "extension" so I can better describe how to redo it.
