FS: '93 Integra Race Car Partout - B18 Engine, Rear Disc, Sway Bar, Brake Pads, etc
Old Jun 1, 2014 | 06:35 AM
Innes's Avatar
Default FS: '93 Integra Race Car Partout - B18 Engine, Rear Disc, Sway Bar, Brake Pads, etc
car is gone...parts are left...
Email -- James@IPGParts.com
Phone - 407-324-4684
All parts are off of a 1993 Acura Integra that are considered vehicle specific.
Here is what we have left parts wise (more pics to come):
Steel Sparco Side Mounts -- sold
Schroth 6 Point HANS Belts - sold
Suspension Techniques Rear Sway Bar, 90-93 Integra, 19mm I believe - $90
(1) Brand New Set of Front Raybestos ST43 Pads for '90-93 Integra (may fit other models) - $150
(3) Used Set of Front Raybestos ST43 Pads for '90-93 Integra (may fit other models) -- $65/each (varying thicknesses...50% plus left, can get pics and specs on what I have shortly)
Mishimoto Aluminum Radiator for 90-93 Integra with Blox Electric Fan installed on it -- sold
ITA Built B18a1 Engine, valve cover to oil pan with intake manifold, distributor, fuel rail, injectors, spark plug wires (no header), Includes a Moroso 5.5 Quart Oil Pan and an ATI Crank Damper, 81.5mm oversize OEM replacement pistons, valve job on cylinder head..built to ITA rules...always made high 130whp on the dyno we used with a generic 4-2-1 tri-y type header -- will have a compression test and leak down test done before being pulled, not sure on exact hours of use but low usage overall -- $1300
**^ just did a compression and leakdown (05-12-14) -- 180, 182, 182, 183 -- 2%, 6%, 1%, 2%
ITA Built B18a1 Shortblock...brand new, never run, 81.5mm oversize pistons, was a back up short block for us and never got used...assembled shortblock (block, crank, pistons, rods), that's it, 0 miles -- $500
Rear Disc brakes including trailing arms, hubs, etc --- Have Blox Spherical Rear Trailing Arm Bushings installed and ARP Extended wheel studs...includes E-Brake Cables (from 90-93 Integra but should fit many more applications, ie. 90-01 Integra, 88-00 Civic/CRX) -- sold
1993 Integra B18a1 Cable Transmission, stock differential, 4.4 Final Drive - $350
Exedy Stage 1 Clutch for '92-93 Integra -- $125 (should fit 94-01 Integra as well once you purchase a new 94-01 integra style throwout bearing)
Used I/O Port Black Net, 18" x 24", SFI Stamped August 2009, has top bar with buckle -- $20
Used 90-93 Integra B Series Shift Linkage..has IPG Solid Rear Bushing and ENS Front Bushings -- sold
Stock PR4 ECU (1992-1993 Integra, OBD1 for B18a1 Engine) -sold
OEM B18a1 Flywheel with ARP Flywheel bolts...still shows machine marks from being resurface -- $70
Used Quaife LSD for B16/LS Transmission - race car use only...relatively low hours - sold
Used OEM Clutch Cable from 90-93 Integra -- $30
Old Jun 10, 2014 | 05:23 AM
Innes's Avatar
Default Re: FS: '93 Integra Race Car Partout - B18 Engine, Rear Disc, Sway Bar, Brake Pads, e
SpoonTeg
Jul 23, 2005 11:25 AM
SpoonTeg
Jul 23, 2005 11:21 AM
trooper0641
Feb 9, 2005 03:46 AM
brbHPR
Nov 27, 2002 08:47 PM
