Je Pistons - B-Series, 84mm
Old May 29, 2014 | 08:37 PM
sponsored1's Avatar
Default Je Pistons - B-Series, 84mm
This is a used set of 84mm Je pistons. They only have a few thousand miles on them, but the customer had fuel issues and ended up washing out the rings. He decided to get a higher compression set when we rebuilt it since he wasn't running a lot of boost anyway. Some skirt scuffs and wear from normal use. All specs check out, includes pins. You just need rings and 4 locks. Link to Je Ring set and locks listed below.
$200 shipped to continental US. I have paypal and am verified.
JE Piston #302410
84mm Bore
77.4mm Stroke
30mm C/D
-11.4 CC Dish
Top Ring - 1mm
2nd Ring - 1.2mm
Oil Ring - 2.8mm
Ring Set-
http://www.jepistons.com/Products/JG1004-3307.aspx
Locks-
http://www.jepistons.com/Products/827-063-MW.aspx
http://www.punkbars.com/pictures/p1.jpg
http://www.punkbars.com/pictures/p2.jpg
http://www.punkbars.com/pictures/p3.jpg
Old May 29, 2014 | 08:42 PM
TravisBiggie's Avatar
Default Re: Je Pistons - B-Series, 84mm
piston 1, is that just crud or is it damaged on the exhaust side? same with piston 2? piston 3 left side, crud or damage? and piston 4, left side, crud or damage? thanks
Old May 29, 2014 | 09:04 PM
sponsored1's Avatar
These have been sitting for about a year. It's minor pitting from some corrosion. Smooth to the touch, just discoloring. Piston 4 does have a few pits in on the top, but can be smoothed out easily. I'll try to scrub the oxidation off tomorrow and take some more pics.
SlaminSohCivic
Dec 10, 2016 06:40 PM
siis2fast
Jun 7, 2005 03:52 AM
int3gra
Jul 4, 2002 06:03 AM
int3gra
Jul 3, 2002 04:55 PM
int3gra
May 23, 2002 03:30 PM
