every radiator I put in ends up leaking
Old May 29, 2014 | 02:52 AM
giovannie23's Avatar
Default every radiator I put in ends up leaking
I have gotten 3 radiators in the last 4 months and noticed I'm starting to leak coolant again all the leaks are coming from the bottom of the rad in the aluminum..
there all AutoZone rads do you think its the rads that suck or is it something else going on ?
Old May 29, 2014 | 03:47 PM
holmesnmanny's Avatar
must be a bad batch ... you can get a Denso radiator from rock auto for about $60 or so.
Old May 30, 2014 | 07:04 AM
professorman's Avatar
Default Re: every radiator I put in ends up leaking
I bought the full aluminum radiator from ebay about 5 years ago, and solved radiator leak once and for all. The weak point on most radiators is the plastic areas. Just save yourself the trouble and get full aluminum.
I am not sure how yours is leaking though.
Skeetzy
19
Nov 14, 2016 08:51 AM
sdinteg
Jun 1, 2010 11:26 PM
tommyt761
Oct 12, 2006 01:00 PM
eastsideATX
Jul 6, 2005 02:56 PM
tkHBseries
Feb 19, 2005 06:48 PM
