Can a z6 distributor for b7 head?
Old May 28, 2014 | 09:15 PM
Minicivic91's Avatar
Default Can a z6 distributor for b7 head?
First I've tried searching but only came up with the opposite setup I had a b2 block with a z6 head that took a crap and got a b7 block&head for cheap and it didn't come with a distributor...so I have my z6 distributor and p28 ecu and am wanting to run the b7 with those if possible while I rebuild my b2/z6 setup.
So my question is will my z6 distributor fit(with mods?) on my b7 head?
This is on a 91 civic but figured id post here since the parts I'm dealing with are from a 95 and I've swapped to obd1 and mpfi already
Old May 28, 2014 | 09:31 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Can a z6 distributor for b7 head?
You'd need to slot the flange as needed to allow proper adjustment. You'll see when you hold the distributor up to the head. Also I believe that only two of the three attachment points line up.
Old May 28, 2014 | 10:08 PM
Ok thanks I'll be getting a b7 distributor but I need this car for work and don't have much cash right now so hopefully this works
Randysi
49
Oct 30, 2011 09:54 PM
CRXSiR71777
Feb 29, 2004 09:25 PM
zanthrax
Jan 22, 2004 09:36 AM
enabi
Jun 12, 2003 01:06 PM
