Weak clutch
Old May 28, 2014 | 04:57 PM
l-82Vette's Avatar
Default Weak clutch
Hey everyone. So, I have a problem with the clutch in my 98 prelude. This morning I was going to work. Started the vehicle and when I pushed the clutch I thought it was a bit weak. Fast forward, I got out of work and could barely get the clutch to engage to shift into first. When I got home, I checked it out and my clutch has to be depressed 50% before I even feel some tension. The springs are fine and I have never encountered this problem before. Was looking for a bit of help in figuring this out. I think I may need to bleed the clutch? The car sat in storage for 6 months and the reserve was empty so I refilled it. Thinking air may be in the line. Thanks for the help!
Old May 29, 2014 | 05:49 AM
Don Jefe's Avatar
Default Re: Weak clutch
If the clutch fluid reservoir was empty/nearly empty then I'd say that you probably just need to bleed the system. Since you'll be down there anyway, I'd also inspect the slave cylinder to ensure that it isn't worn and leaking.
Old May 29, 2014 | 11:16 AM
snobordboy's Avatar
Moderator
Yup bleed the system, and it obviously has a leak, either slave or master.
Old May 29, 2014 | 03:57 PM
holmesnmanny's Avatar
find and fix the leak, then bleed the system
Old May 29, 2014 | 04:21 PM
LudeImagination's Avatar
i had this problem in my 98 prelude as well. my slave cylinder was sticking which caused my pedal to be weak and when applied it barely disengaged the clutch. replace the slave cylinder and i would recommend replacing the master cylinder as well since they are like units.
integragsssr
Feb 6, 2009 08:54 PM
iLOVEmyEMone
Oct 28, 2005 05:31 PM
Perfourmance
Nov 16, 2004 11:08 AM
OSG 97 ITR
Apr 17, 2004 10:11 AM
stRtypR25
Jan 21, 2003 08:45 PM
