02 accord transmission
Old May 28, 2014 | 08:27 AM
toolbox21's Avatar
Default 02 accord transmission
I have a 2002 accord se with 175,000. Its sliping pretty bad between 1st and 2nd the rest of the gears seem to be shifting fine, also no check engine lights but when hooked up to the scanner its throwing a transmission range sensor error, is this something I can change and make the slip to stop, or is that error code not related to my issue, I know accords are notorious for bad trannys
Old May 28, 2014 | 10:49 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 02 accord transmission
Check that the range sensor is properly adjusted. It may or may not affect how the gears are affected.
Old May 29, 2014 | 10:00 AM
toolbox21's Avatar
Okay ill do that, hopefully it will take away that slip from 1st to 2nd, my d4
Light isn't blinking so that's a good sign, I really dont want to have to get a new tranny, now when I picked the car up I immediately changed the transmission fluid and replace with honda atf, and noticed a grayish sludge come out after all the fluid drained, is there anyway to get a full flush to get all of that out or just multiple fluid changes
Old May 29, 2014 | 11:04 AM
MAD_MIKE's Avatar
MM Gruppe B
Use a cleaning solvent like Trans Tune, do not use a stop leak, this will help break down the varnish and goo. Only way to remove the fluid is to drain the pan. Do not power flush.
logansuttle
Apr 2, 2017 05:27 PM
ZekeZG
Apr 5, 2016 01:24 PM
toolbox21
May 28, 2014 10:29 AM
miguel11691
Mar 6, 2012 10:58 PM
stevo accord
May 2, 2009 10:40 AM
