Spec 98 bottom block California Smog?
Old May 28, 2014 | 07:34 AM
PeterVSays's Avatar
Default Spec 98 bottom block California Smog?
Before I spend anymore money. I want to know if the Spec 98 bottom block with a 2001 USDM head will pass California Smog, I have an inspection soon after I redeploy back to the states. I know that the 98 has a 11:1 cr while the USDM ITRs only had a 10.6:1 cr. Any advice to make it pass smog?
Old May 28, 2014 | 03:02 PM
R6Elmo's Avatar
Default Re: Spec 98 bottom block California Smog?
i don't think you'll have any issue with smog. It'll pass the visual fine, they don't check block castings or the like for inspection. Make sure the intake and exhaust are stock, and that the ECU is a USDM one for your year.
Old May 29, 2014 | 01:56 AM
PeterVSays's Avatar
thanks man.
Old Jun 3, 2014 | 12:33 PM
EpHatchy's Avatar
your goin to need to reuse the 01 usdm oil pump and timing cover because of the sensor that is mounted on it.
MUGEN_EG95
11
Apr 17, 2008 04:29 PM
acuteviet
Sep 10, 2006 01:59 PM
sd_pinoy858
Mar 7, 2004 07:29 PM
Cashflo
Jan 14, 2003 12:33 PM
Spade
Oct 12, 2001 07:38 PM
