Coolant hose leaking - 97 hatchback
Old May 28, 2014 | 12:29 AM
lalo1609's Avatar
Icon6 Coolant hose leaking - 97 hatchback
Hello, every body well I just want to make this easy and fast a few days ago my car started leaking coolant. The first thing I did I checked the radiator and the main hoses, but none of them look to be bad what I did then was to fill up the radiator again and I drove it for a few hours. I discovered where the coolant was leaking which is a small hose just above the oil filter(posted some pictures) I been busy these days, so I have not fix it. what I want to know is there anything else associating with this leaking like a bad water pump, I know I have to replace the hose(so I fix it at the same time), but the leaking does not happen all the time. Please help me with this!
Old May 28, 2014 | 03:11 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Coolant leaking 97 hatchback
Trying to figure out if this is a trick question. The hose is leaking from the back of the block, no where near the water pump. The hose is leaking.
Old May 28, 2014 | 04:29 AM
Former User's Avatar
Replace the connecting pipe and the attached S-shaped hose above the connecting pipe.
prodjay10
Honda Civic (2001 - 2005)
May 27, 2015 09:23 AM
myshelly2010
Apr 18, 2013 02:58 PM
2kgsrt
Apr 5, 2010 09:00 PM
lax1089
Mar 30, 2007 04:11 PM
Jeffrey9
Nov 16, 2005 03:39 PM
