Turn signal, cluster, seat belt problems
so my turn signal lights fuse popped and everything on my cluster my clock and even my seat belt stopped working...i first replaced the fuse with a slightly larger amperage fuse and a few days later it popped again....my hazard lights still work i can hear the relay click on n off when hazards go on....has anyone have the same issue?
If your wires look good and everything seems to check out at a dead end, I'd recommend popping open your ICU and check if the circuit is fried. Its located on the backside of the fusebox.
galvy22
Dec 30, 2008 03:39 PM
timntam
Feb 3, 2006 11:10 AM
SiR HatchAlot
Mar 28, 2004 09:31 AM
