Ef Handling issues
Old May 26, 2014 | 05:27 PM
SleepyEF's Avatar
Default Ef Handling issues
So my EF hatch is acting strange i just bought this shell and did a b18b1 swap and after getting it running good it comes to the test drive.
The car when ever you hit a little bump it jumps hard to the right and in the rain it slides all over the place. I think it could be an allignment issues but im not good with shells not much experience in that field iv rebuilt more engine than iv changed Suspension components.On another note i got a hold of the guy who sold me the shell and he said he just recently replaced the tie rod with no adjustment. Any advice guys?
Old May 26, 2014 | 05:37 PM
whited's Avatar
CRX God
Default Re: Ef Handling issues
Take it for an alignment. If there is suspension part bad, the shop should tell you. Replace the part yourself, then take it back for the alignment.
Old May 27, 2014 | 04:32 AM
bheinen74's Avatar
steering rack binding, and end rack bushing shot.
My CRX I just bought did this, and when i took it apart to replace the end rack bushing, discovered the inside was full of rust dust, and basically, after removing the rack, discovered it was dry and almost locked up.
Old May 27, 2014 | 01:35 PM
SpeedOFsmell's Avatar
My 1990 Si did the same thing. Crazy-off alignment angles was all. Maybe make sure your ride height is even all around too (before having a shop align it).
also, i'm sure your front control arm bushings are destroyed by now. change em.
SleepyEF
Jul 14, 2014 06:05 PM
Ludehrt
May 5, 2009 01:52 PM
Ludehrt
May 3, 2009 02:40 PM
slow91crxdx
Nov 7, 2006 06:17 PM
Eggman
39
Mar 31, 2005 04:29 PM
