type r throttle body on b17a??? help!
Old Oct 30, 2002 | 02:01 PM
Death_to_Thieves's Avatar
Default type r throttle body on b17a??? help!
Hey . I have a 92 GSR and I bought a bored out CTR throttle body with TPS. BUt the problem is that my stock TB doesnt have the map sensor on the TB . My map sensor is on my firewall. But the CTR Tb has the map sensor on the TB. Also the CTR tb doesnt have the vacuum line that connects to my map sensor on the firewall like my stock TB. It just has the holes for the map sensor itself. So basically I'm asking if I can use this TB at all due to the fact that my map sensor is on my firewall and the CTR map sensor is on the TB itself. Please help
Old Oct 30, 2002 | 02:29 PM
Jared's Avatar
Default Re: type r throttle body on b17a??? help! (8000KReV)
extend your wires and use the map sensor on the ctr t/b.
Old Oct 30, 2002 | 02:31 PM
Bserious's Avatar
This is an easy fix, you will use the MAP sensor on the Throttle Body....hopefully you do have the MAP. All you need to do is unplug the C312 connector (the one that plugs into your MAP on the firewall) and lengthen the 3 wires enough to reach the MAP sensor on the Throttle Body and plug it in. Check it out, the connector will plug into either MAP sensor.
Old Oct 30, 2002 | 03:44 PM
Default Re: type r throttle body on b17a??? help! (Bserious)
thanks to everyone.. keep the info rollin in. Yo BSerious, I have a 92 GSr and I would like to shed off a few pounds on it myself. What mods have you made to shave some pounds off your ride??
Old Oct 30, 2002 | 04:12 PM
Will a map sensor from a 93 JDM B16a work with my JDM Civic Type R throttle body???
jphil101
Apr 2, 2010 11:36 AM
Pooper
Oct 16, 2006 09:19 PM
SVOboy
Mar 26, 2006 11:48 AM
comptechgsr2000
May 8, 2002 03:53 PM
