Kelford 176-t impressions and idle
Who is Mr Robot?
good luck, I know of literally 0 people using these cams.
and you can't expect any performance camshaft to idle like stock... It just isn't possible. You can raise the idle and tune the idle timing and fueling to dial out some of the lop but it will never be "stock"
The biggest issue you see with most people running large cams (regardless of vehicle make) is that they have 0 clue how to properly tune idle
I've run a few of the Kelford T-176 camshafts. They have similar characteristics of idle like the GSC T1s. Now, I admit, the only have experience I have with these are with GT35Rs, but they do very well for the upper end power and helps with the powerband for larger turbos.
But like with other "REAL" camshafts, do not expect OEM idle.
They sound similar to this.
Last edited by TheShodan; May 27, 2014 at 08:46 AM. Reason: embedded video link used instead of written description
