Can a blown head gasket look like this?
I just took the head off of my F23A1 to hopefully replace the head gasket and be done with it.
The symptoms were that oil was getting into the coolant, and a lot of it. I bought it like this so I don't know if it was after a day, a week or a month.
The head gasket doesn't have any obvious breaks in it, it's the 3 layer metal one though, could it have "de-laminated" or something and let oil get into the water jacket? I'm really really hoping the block or head isn't cracked.
Should I go ahead and clean everything up and put the new head gasket in it and hope for the best? I'm not too concerned about having to do it again, it's just that I kind of need this car up and running soon. I don't want to start the car up and have it immediately do the same thing.
Otherwise, I'd probably just look for a new engine, but I'd rather not do that since pulling an engine with an auto tranny isn't that much fun.
Here are some pictures
The head gasket doesn't break and certainly doesn't blow out. It's kinda of a wrong name to give it, what happens is the head and/or block warps and the head gasket simply doesn't seal anymore. There are many symptoms but it's clear from that picture that there is coolant in the oil as you can see the sludge.
You will need to atleast have the head resurfaced and check the block for warpage just to be on the safe side. If you just put another gasket on there it won't make it a month before the gasket goes out again.
Did you also check diagonally across both faces?
If the surface is warped, a straight edge may check out good down the center or sides but from opposite corners it may show the twist(warp) in either deck surfaces.
If that is fine there may be a leak in the oil cooler(if equipped) or AT(if equipped) cooler lines through the radiator.
No oil cooler, but there is an AT cooler in the radiator. That could possibly be it....The trans fluid doesn't seem to have coolant in it though...
The cylinder walls all look smooth, as does the head. The freeze plugs are still in the block so I don't think the block froze and I haven ever heard of a cracked cylinder wall from stock applications.
Another question.
If I set the head and block to TDC on the compression stroke on cylinder 1, then I remove the head and rotate the crank 360 degrees so it would be on the compression stroke for cylinder 4 and then put the head back on that would work right?
I'd assume the block is "dumb" and TDC for 1 and 4 and TDC for 2 and 3 is the same whether it's on the compression stroke or the exhaust stroke.
And another question. When VTEC kicks in it opens both intake valves and when it's not kicked in only one opens correct?
Another question.
on sohc engines it closes one intake valve but on dohc engines both will be open
ok cool. I was wondering if the ECU determined which cylinder gets the fuel and spark. I guess it's not totally based on the crank positioning then.
That head gasket looks like **** and needs to be replaced.
I have fallen for the straight edge flatness test trick before. You can't test flatness with a straight edge and your eyeballs.
Send the head and block to a machine shop to determine the flatness, or do a trial by error with a new head gasket to verify.
