LS integra burning oil
Old May 25, 2014 | 09:32 PM
kprotege5's Avatar
Icon6 LS integra burning oil
Hey there, I wonder if someone here can give me their opinion on my issue.
I have a LS integra with a b18b1 engine (unknown mileage) and lately I changed the ECU ( old one was running rich ) for a stock p75 ecu. I also changed the exhaust( 4-2-1 headers, no cat, 2.5" catback ) and it started burning oil. It is definitely burning, not leaking. There is blue smoke coming out of the exhaust and it smells bad when you step on it. My guess is that the rings are going bad but how come it only did that after changing the ecu and exhaust? It's running 5w30 oil( I added some thicker oil to fill the burned oil )
Any thoughts? The PCV valve seems to be working good.
Additional info.
It doesn't seem to burn that much oil if driven like grandmas but anything past 5k rpm will start smelling bad and burning oil.
Thanks!
Old May 26, 2014 | 07:10 PM
safedriver's Avatar
Default Re: LS integra burning oil
What year is your LS?
I guess that it's between 98-01.
But you didn't mention a primary nor secondary O2 sensor.
Maybe you car is older and isn't OBD2.
Old May 27, 2014 | 02:03 PM
kprotege5's Avatar
thanks for your reply, its a 97 and it's obd2. I have the first o2 sensor plugged in and working, however the other one was cut off and it gives me a CEL... it still wouldn't work anyways since there is a test pipe instead of a cat
shortyforlifex
Jun 24, 2011 12:16 AM
carbonemt
Apr 19, 2011 10:03 AM
vtek9
Jan 10, 2008 06:25 PM
naahnaah
Dec 15, 2007 04:06 PM
IggDawg
Nov 12, 2003 11:23 AM
