"Oil" in radiator resivoir
Old May 25, 2014 | 06:47 PM
terrywedlake's Avatar
Default "Oil" in radiator resivoir
As the title says I have what I believe is oil in my reservoir. Just traces, floating around and sticking to the sides. I just noticed it recently when I was changing my oil. The oil I took out was dark, but not milky, also the car is not overheating, and quite frankly runs like a champ. It is a manual so no transmission cooler. I feel that it is the head gasket, and ordered the necessary parts to do the job. So what do you guys think before I do this and find out that's not the problem? Haven't ran any tests, but all I can think is that the gasket is at least starting to fail. Thoughts?
Old May 25, 2014 | 06:49 PM
tony_2018's Avatar
Fish Twig
Default Re: "Oil" in radiator resivoir
Pics would help
Old May 25, 2014 | 06:50 PM
Pics of the fluid I'm assuming.
Old May 26, 2014 | 01:03 AM
holmesnmanny's Avatar
Compression test to find out of the head gasket is no longer sealing properly. If not, then it could be a pinhole leak in the block which is uncommon but happens from time to time in some Honda blocks. It's a casting error.
Old May 26, 2014 | 03:10 AM
Azimmer
24
May 9, 2012 02:34 PM
silent702
Feb 9, 2010 08:22 AM
apeek
Jan 23, 2008 07:28 PM
JWHATCH23
Dec 3, 2006 06:00 PM
