Stock mounts?
Old May 23, 2014 | 09:03 PM
Uljima's Avatar
Default Stock mounts?
Hi, I just replaced my stock mounts with hasport 62a and The vibration is terrible, for some reason my buddy's car also have the same mounts on a b18c and it doesn't have as much vibration as mine so i want too go back too stock.
Thing is will the vibration get better over time? With the hasport?
If the vibration doesn't stop can I just change the front too stock and just leave the rear hasport mounts?
I have a- Honda Civic 2000 Hatchback (ek)
with a b18b1 engine (3 bolt mount)
Old May 24, 2014 | 02:41 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Stock mounts?
62a is not that hard. Should have gotten hard rubber. There will always be vibration with these things. You'll more than likely just get used to it. We just put simple inserts in the hatch and it vibrates like all hell broke loose.
Old May 26, 2014 | 07:15 PM
alvarez760's Avatar
Go stock mounts . With polyurethane inserts
Old May 30, 2014 | 11:06 AM
silenec's Avatar
Or DIY http://www.superhonda.com/forum/f94/...mounts-204274/
Old May 30, 2014 | 02:10 PM
hondamark35's Avatar
I went the DIY route. About 80a based on the product information. at first it was pretty annoying. however it did eventually "break in" and soften up a bit. it's not nearly like stock. I prefer a little feed back anyway so it strikes a good compromise between stiffness and comfort.
smokey.23
22
Mar 24, 2009 09:01 PM
Top-Fuel
Mar 23, 2006 06:45 PM
vangc6780
May 1, 2005 10:14 PM
crxgator
Dec 30, 2003 08:53 PM
