1992 Honda Accord stalls only when in drive?
Old May 23, 2014 | 07:18 PM
DeleriumTrigger's Avatar
Default 1992 Honda Accord stalls only when in drive?
Hello all, mechanically challenged biologist here. I have a 1992 Honda Accord with just under 200K miles. It's been a great car and got me up through college graduation, and I'd like to squeeze a little more life out of it if I can before finally getting a newer model.
Today it developed a rough idle at stop signs and traffic lights, and the engine wouldn't respond when I tried to accelerate after a stop. The engine runs fine and revs normally when in park or neutral, but dies completely when it's in drive and I hit the gas. Hitting the gas lightly seems to be less of a catastrophe, but hitting the gas enough to enter the flow of traffic kills the engine with a dramatic lurch and it;s a struggle to turn it back on. I've tried Lucas Fuel Injector Cleaner on the chance it was a fuel injector issue, but after letting the car run for an hour with the cleaner it's still acting the same.
I was thinking spark plugs/wires or IAC, but wanted a more expert opinion. If it's something I can do myself, I'd like to.
Thanks in advance for your time!
Old May 23, 2014 | 09:12 PM
tim73's Avatar
Default Re: 1992 Honda Accord stalls only when in drive?
I was thinking EGR passages? Have those been cleaned out? Id start with that.
Old May 23, 2014 | 10:21 PM
MAD_MIKE's Avatar
MM Gruppe B
Although EGR being stuck open may cause a stall at idle if the EGR valve sticks open, have you looked at your FITV/IAC or vacuum hoses?
How is the idle when it is cold? When warm? Last time it had a tuneup?
Also Location, as some of us are suckers for helping a 'local' out.
nematon785
Jul 17, 2015 06:25 PM
Dadragonlord289
Jan 25, 2015 03:17 PM
95hondaAccord
Feb 13, 2012 05:48 PM
bmacobwn
Mar 21, 2007 02:17 PM
