PCV Valve Hose
Old May 22, 2014 | 08:46 PM
JHipps's Avatar
Default PCV Valve Hose
Where does the other end of the hose run to? My intake mani? Or somewhere else?
Old May 22, 2014 | 08:59 PM
Former User's Avatar
Default Re: PCV Valve Hose
Rule sticky - please read.
Car and engine information is required for all tech threads.
Old May 22, 2014 | 09:03 PM
JHipps's Avatar
Sorry.
1995 Honda Civic CX Hatchback
LSV Motor - B18A1 Block/ B16 Head
Intake Mani is Edelbrock Victor X
Garrett GT35R Turbo
Old May 23, 2014 | 06:06 AM
B_Swapped93's Avatar
you should have a catch can set up with that set up...considering the victor x is strictly a turbo manifold does it even have a pcv hole?. other wise yes it would/should go to the intake mani.
Old May 23, 2014 | 02:32 PM
gooblinn258's Avatar
The pcv is placed on the b18a1 on the IM near the injectors. The top part of the valve (the part you can see), connects to a tube that runs into the IM again. IT is connected to the top of a black box bolted to the back of the block called the breather.
rickpenacampos
Jan 30, 2015 12:07 AM
Nickabeans
Jun 11, 2014 02:34 PM
ryanangelo212
Mar 20, 2013 12:09 PM
s10cky
Nov 20, 2006 12:24 AM
