93 Accord Back Seat Removal
Old May 20, 2014 | 11:06 AM
istabrak's Avatar
Icon2 93 Accord Back Seat Removal
Greetings to all,
I am trying to remove the rear seat from my 93 Accord.
In the manuals, they mention two 10 mm bolts.
I could not find these bolts when I looked inside the trunk.
Also, there is a key lock behind the seat under the rear window with the following note on it ( Turn to unlock the seat back).
When Iinserted the ignition key and rotated it, the rear seat did not fold forward.
Could you please provide some details/photos/videos?
I did a lot of search but did not find the needed details.
Thx and BR
Ista
Old May 20, 2014 | 12:45 PM
dahubby's Avatar
Default Re: 93 Accord Back Seat Removal
SO you may need to pull your seat forward when you put the key in. If not, go in the trunk and there should be a latch that releases the seat forward (right where the keyhole is). The two 10mm bolts are near the rear of the seat between the seat and the frame, near the outer edges. Hope this helps. I dont have photos, sorry. Also you have hooks on the front that can be a pain soetimes. I think you may have a 10 in hte middle also.
Check this out, looks like the same process pretty much
Old Jun 3, 2014 | 07:13 AM
istabrak's Avatar
Greetings to all,
Thanks for the info.
I was able to remove it using the T-handle from the trunk and then followed the procedures.
BR
Ista
01celica_gts
Jan 17, 2017 12:31 AM
bannerwelder
Feb 1, 2010 02:31 PM
89sicivic
Mar 9, 2007 04:57 PM
jgrif08
Oct 23, 2006 06:08 PM
JonathanRuiz
Oct 28, 2004 10:31 PM
