driver door swap, 92cb7coupe
Need to swap out my driver door, color code is (BG-30P-3). I have a 92 coupe, will a wagon or a sedan driver door be a direct fit, and if so what year are compatible to a 1992?
Back in the day I would easily locate a perfect year and trim fit at the JY, but now I've noticed our CB7 are becoming more and more scarce.
Let me know what you now by sharing the knowledge.
Thanks
Thanks
K, had to do my own research & this is what I got. 92 & 93 coupe r only compatible, other year coupe, sedan and waggon are to 10" short and have a diffirent harness and the trim/molds does not match up.
unplug the wire harness for the door underneath the dash by the kick panel and take off hinges from door. a quick google search should head you in the right direction.
messeduprex
Mar 10, 2006 01:17 PM
