hiccups on slow driving low rom
Old May 20, 2014 | 08:50 AM
gabrielsousa's Avatar
Default b16a1 hiccups on slow driving low RPM
hello
when i'm on slow driving, low rpm 2000 the engine hiccups a little...
my idle fluctuates, i think this is related ...
how do i fix this ?
thanks
Old May 20, 2014 | 10:22 PM
slowcivic2k's Avatar
Default Re: hiccups on slow driving low rom
Ford Expeditions, F150's and Excursions with 5.4L V8's, not to mention the venerable Crown Victoria 4.6L, are prone to the kind of problem. Lincoln's are the same way.
Please be kind and at least tell us some basic information, like, what you drive, what you have done to it, when it started, what was the last thing you did to it (or a shop did) ETC.
Old May 21, 2014 | 12:42 AM
sorry,
-clean the AICV and FITV
-tried 3 TPS. 2 used 1 new
-tried and clean 2 TBs
-bleeding air out of coolant system
-check for my vacuum routing didn't found problems and used carburetor cleaner
-tried other spark cables from a B18C4
engine cold dont fluctuates .
engine is running and fluctuation, i stop, and start , the engine stays 30s without fluctuations
here a video of my idle (use headphones) on pc speakers its hard to notice.
Old May 21, 2014 | 02:51 AM
here´s a video when i unplug the TPS wire
Old May 22, 2014 | 10:19 PM
prodjay10's Avatar
I think I found your problem. One of your valve cover nuts is missing! Just kidding.
Even with that issue, sounds like it runs pretty good.
Old May 23, 2014 | 02:31 AM
made other test
with engine running and fluctuating...
i unplug a spark cables, plug again and stops fluctuating
Nic0807
Honda Civic (2001 - 2005)
Dec 4, 2018 08:50 AM
beocop
Jul 2, 2017 05:19 AM
KimvdLinde
Jun 29, 2013 01:40 PM
Xx98civiclxX
Dec 26, 2009 02:43 AM
nicklp60452
Jul 14, 2008 02:53 AM
