Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
What's the best way to make my 2006 ride smoother?
Old May 19, 2014 | 01:32 PM
ssking111's Avatar
Default What's the best way to make my 2006 ride smoother?
I've got about 150k miles on my 2006 Civic. The ride seems to be getting rougher and rougher. What's the best way to smooth the ride out? New shocks? Which ones? Springs too? Which ones? I know its a Civc and it's never going to ride like a Mercedes, but its got to ride better than what it is right now. Any suggestions? And No, I'm not looking to lower it at all. Just want more comfort.
Old May 19, 2014 | 06:36 PM
97emsedan's Avatar
Default Re: What's the best way to make my 2006 ride smoother?
Replace the current suspension with new factory parts to restore the ride quality. Anything else will not be the same.
Old May 20, 2014 | 08:18 AM
DaveSi677's Avatar
i wouldn't go with a softer suspension then stock as it will alter the way the car handles!
Old May 20, 2014 | 10:59 AM
Todd00's Avatar
I said I don't want a title!
Ride is crap because your shocks are worn out. This should be pretty obvious. Shocks don't last 150k miles, period.
Replace your shocks and the "smooth" ride will return. Also, have whoever does so inspect your bushings as well.
And don't buy $25 shocks from the local AutoParts store. Get OEM parts.
Old May 20, 2014 | 01:39 PM
av911's Avatar
Any other indications of bad shocks?
Old May 20, 2014 | 02:16 PM
97emsedan's Avatar
Push down on a corner of your car. If the car settles under the pressure, the suspension is done.
If you hear squeaks and rattles as you drive then you know the shocks are gone.
Have a listen to your car as you drive, it will tell you what you need to know.
square_1
Honda S2000
Nov 17, 2011 09:35 AM
eg9
Suspension & Brakes
Jul 18, 2006 01:29 PM
slowr6
Suspension & Brakes
Dec 3, 2005 10:32 PM
my01accordex
Jul 21, 2004 11:36 PM
vi3t187boi
May 16, 2003 04:17 PM
