Rebuilt JDM 95-97 ITR JDM 92-00 SiR/CTR 92-95 Delsol Transmission NON LSD 4.4FD
CONTACT: JOEL 909 728 5033
PRICE: $1450 WITHOUT CORE / $1100 WITH CORE EXCHANGE
ITEM: *REMAN* JDM 95-97 ITR JDM 92-00 SiR/CTR US 92-95 Delsol Transmission
YOU ARE BUYING A REBUILT JDM 95-97 ITR JDM 92-00 SiR/CTR US 92-95 Delsol Transmission. RECONDITIONED TO MEET OR EXCEED OEM STANDARDS.
PRICE INCLUDES CORE CHARGE. ONCE YOUR REBUILDABLE CORE IS SENT BACK YOU WILL BE REFUNDED THE CORE CHARGE OF $350.00.
* If your core is non-salvagable you will be refunded contingent upon estimated damages; or it will be returned to you upon arrangement.
GEAR RATIO
1st 3.230
2nd 2.105
3rd 1.458
4th 1.107
5th 0.848
R 3.000
FD 4.400
* Note: NON-LSD
NEW
Case Tumbled & Cleaned ( oem type satin finish )
1-2 Sleeve
1st Friction Ring
2nd Friction Ring
3-4 Hub & Sleeve
3rd Gear
5/r Sleeve
1-5 Carbon Synchros
All new bearings ( includes differential )
All new seals
Nite Grind Plaque of Certified Rebuild Quality
WARRANTY
* CARBON SYNCHROS DO NOT QUALIFY FOR 12/12 WARRANTY THEY ARE DESIGNED FOR OFF-ROAD USE.
SO WHAT TYPE OF WARRANTY DO YOU GET?
Warranty is offered contingently upon review, for any defects caused by build(er) error. Your repair labor expense is on the house!
Manufacture defects on sublet parts are 12/12 ( 12mo. 12,000 miles ) Items covered as follows:
1-2 sleeve
3-4 hub/sleeve
5/r sleeve
**I do not cover labor costs of removing or reinstalling the unit from your vehicle, warranty repair approval will be contingent up inspection**
**I do not cover labor costs for repairs due to manufacturer part failure**
ALL OF THE TRANSMISSIONS I SELL ARE BENCH TESTED MAKING SURE 1-5 GEARS AND REVERSE ARE OPERATIONAL
*CLICK IMAGES TO ENLARGE*
GEAR RATIO
1st 3.230
2nd 2.105
3rd 1.458
4th 1.107
5th 0.848
R 3.000
FD 4.400
* Note: NON-LSD
NEW
1-2 Sleeve
1st Friction Ring
2nd Friction Ring
3-4 Hub & Sleeve
3rd Gear
5/r Sleeve
1-5 Carbon Synchros
All new seals
WARRANTY
1-2 sleeve
3-4 hub/sleeve
5/r sleeve
JDM_JNKY
Apr 2, 2014 07:42 AM
JDM_JNKY
Oct 22, 2011 01:29 PM
