91 cb7 need help!!!!
Old May 18, 2014 | 11:04 PM
twotone65's Avatar
Default 91 cb7 need help!!!! with my intake mani
I want to gut my intake manifold how do I go about doing that f22a1 by the way
Old May 19, 2014 | 10:56 AM
chrisnick's Avatar
Why? You're going to kill the powerband.
Old May 26, 2014 | 09:58 AM
twotone65's Avatar
Default Re: 91 cb7 need help!!!!
What do you mean??? I heard that it helps it breathe better idk much
Old May 26, 2014 | 01:03 PM
MAD_MIKE's Avatar
MM Gruppe B
It has a primary and secondary runner in the intake, at low revs only the primary ports are open, when more air is needed the secondary ports open. This is to allow proper air velocity at low and high engine revs.
The port runners are sized to aid in producing torque/power for a given RPM band. If you remove the butterflies this will reduce low end power.
Only do this modification if there is extensive engine changes that require the added air flow.
Old May 31, 2014 | 10:12 AM
twotone65's Avatar
Ok thank u
egzo04
Jan 5, 2006 02:27 PM
PreludeSiTdriver
Oct 24, 2004 06:03 PM
k-mart
Apr 9, 2003 08:59 AM
Sukebei Oni
Oct 24, 2002 09:43 AM
