timing belt... what's the WORST that can HAPPEN?????
Old Oct 30, 2002 | 12:15 PM
Charlie Moua's Avatar
Default timing belt... what's the WORST that can HAPPEN?????
Well my car is at honda right now. They tell me that the timing belt broke and water-pump blew.
I was driving at about 60mph/2500RPM when the car died.
*now the got done replacing timing belt & ater-pump..... the honda tech guy says that the car is not running right like it should.
******what could it be?
-what else could could possible be damaged(inside motor) rings? spun a bearing?
blow a rod? tell me ??????
Old Oct 30, 2002 | 12:26 PM
The_Oz's Avatar
Default Re: timing belt... what's the WORST that can HAPPEN????? (Charlie)
First thing to occur is valve-to-piston contact.
Regards,
Oz
Old Oct 30, 2002 | 12:29 PM
satan_srv's Avatar
Default Re: timing belt... what's the WORST that can HAPPEN????? (The_Oz)
bent valves
Old Oct 30, 2002 | 12:34 PM
Spade's Avatar
Default Re: timing belt... what's the WORST that can HAPPEN????? (satan_srv)
bent valves
Not just.....bent/broken valves, Holes in pistons, destroyed sleeves, rod and crank damage, oil pump, water pump.....the worst thing that can happen is total loss of the engine which in turn at high speeds will take the tranny with it.
Old Oct 30, 2002 | 01:19 PM
sleeprhatch's Avatar
can you hear all that money coming out of your pocket?
sorry to hear about that bro
Old Oct 30, 2002 | 03:23 PM
Jesse H's Avatar
Default Re: timing belt... what's the WORST that can HAPPEN????? (DOHC_VTEC)
Just why I wish we all had timing chains... Oh well.
slightly louder and more parasitic drag
Old Oct 30, 2002 | 03:54 PM
HXMan's Avatar
Default Re: timing belt... what's the WORST that can HAPPEN????? (Jesse H)
Worth it.
Old Oct 30, 2002 | 04:04 PM
Default Re: timing belt... what's the WORST that can HAPPEN????? (Spade)
bent valves
noooooooooooooooo not what i wanted to hear but at least i know the worse case senerio....
I just bought thsii motor like 1.5 years ago from nippon motors. right know the total is about $1400(towing, new timing belt, water pump, labor, and wheel bearing......not sure if they did the wheel bearing yet, hope not)
*******guys tonight please help pray for my motor in any way you can
Old Oct 30, 2002 | 04:05 PM
but i was only at 2500 rpm will it cause all that damage????
Old Oct 30, 2002 | 04:13 PM
IN VTEC's Avatar
Not likely, but you never know with interference motors.
Also, a Mercedes mechanic told me that timing chains can and will still stretch and break, just not as quickly...and that you should still replace the timing chain. The only thing that's really changed is the service interval.
At the minimum, you should run a compression test to see if you're losing compression through a bent or cocked valve. If you did lose compression, pull the head and look at the piston(s) and valves. Fill the ports with carb cleaner and check for leaks past the valves.
No need to freak. Just fix the problem and carry on.
[Modified by IN VTEC, 7:16 PM 10/30/2002]
Old Oct 30, 2002 | 06:46 PM
CivicEK.PDX's Avatar
Default Re: timing belt... what's the WORST that can HAPPEN????? (IN VTEC)
You should have replaced the belt anyways when you bought the motor.
Old Oct 31, 2002 | 04:33 AM
Default Re: timing belt... what's the WORST that can HAPPEN????? (CivicEK.PDX)
yeah but when i bought i got the motor from nippon it was in superb condition, and the timing belt was still very strong.
**UPDATE**
honda just called me back and said that there is a problem in the 3rd cylinder. we will see what happends
Old Oct 31, 2002 | 06:40 AM
MikeMAN's Avatar
the sound i can hear is the sound of vasoline sloshing on ur buttox, as the salesman says "whooose ur daddy"
seriously tho, I would check the top of all ur pistons (or have them do it)
either way, it is something probably pretty expensive.
mike
Old Oct 31, 2002 | 06:42 AM
NonovUrbizniz's Avatar
Loved
does anyone in here actually know what block he has and if it is a interferance motor.
cuz my d16z6 is zero-interferance. so it wouldn't matter if i was doing 7.2k and my timing belt went.
I have to agree with the timing chain coment though. I wish these things had'm and i've been thinking about swapping mine for one eventually.
Old Oct 31, 2002 | 07:40 AM
b18b98's Avatar
Default Re: timing belt... what's the WORST that can HAPPEN????? (HXMan)
Worth it.
I had a timing chain break in my 86 Mercury Topaz. It killed the whole motor. It did have like 187,000 miles so wear and tear did take its toll.
Old Oct 31, 2002 | 07:41 AM
MikeMAN's Avatar
Default Re: timing belt... what's the WORST that can HAPPEN????? (b18b98)
nice avatar dude lucky elmo
Old Oct 31, 2002 | 11:15 AM
Default Re: timing belt... what's the WORST that can HAPPEN????? (MikeMAN)
------------UPDATE-------------
honda calls me back they tell me that the 3rd cly is out. they want me to spend another $1200:
*take off aftermarket parts
*take off head
*prep and clean head
*ship out head to machine shop to have it worked on
*port & polished, new valve & valve seals miscellanous gaskets
*labor putting all back together.
***right now it's runing but really poorly.
--total cost was $950(timing belt, water pump, towing and labor) and my car still isn't fixed.
**** honda... they wasted my money for *****.
Old Oct 31, 2002 | 11:56 AM
lewd43's Avatar
my timing belt snapped at idle after just 54k on the odometer, that car is 7 years old, it bent all the valves from the 2, 3, and 4 cylinders, so whether or not ur at some high rpm or a moderate one such as 2,500, they're gonna have to check to make sure
Old Oct 31, 2002 | 12:54 PM
Kamin's Avatar
dude
YOU broke your timing belt
that is what makes your engine WORK
dont blame them because they tried the basics first before they ripped your head off.
you need a new motor now. sorry. look on the birght side, you can upgrade.
Old Oct 31, 2002 | 02:27 PM
rybred's Avatar
same thing happened here, at idle though, my timing belt fell off, because the ****** idiots at honda didn't put the main bolt that holds it together properly, and bent two of my valves, that was at idle, hope you don't have any cracked pistons man, that would be very shitty!
I would suggest to get your head re and re done through the machine shop yourself, they probably have some regular guy, that would do it for alot cheaper then honda would, that's what i did! Preferably a private guy, you'll save some cash! Seems like you need to!
Old Oct 31, 2002 | 06:12 PM
Default Re: timing belt... what's the WORST that can HAPPEN????? (KAMiN)
dude
They should have done a compression test first off. Also ask them to make a package deal to fix your car.
OR pull the head and send it to the machine shop with some valves, vlave seals and some money. To replace the valves it gonna run $50 min. May be more if they have to check each valve to figure which is bent. I just did a LS motor; headgasket, timing belt, pistons rings and valve seals and other misc. gaskets and selas. $1100 OEM parts included. If you can find a compentant mechanic around you take it there. Good luck .
Old Oct 31, 2002 | 07:52 PM
95GS-R's Avatar
*take off head
Well since your car is going to be out of commision for a while you might as well get that work done yourself instead having to pay them to have someone else do it. Rebuild it with some quality parts.
How many miles (total) on the motor when this happened?
Old Oct 31, 2002 | 10:31 PM
KTeller8's Avatar
Default Re: timing belt... what's the WORST that can HAPPEN????? (95GS-R)
from what i hear.. this was a swapped car..
dude you should of told them that in the first place
i got some parts if you need them.
stock f22 stuff... also might have a h22 head available. not sure yet
i need a h22 block. i have aftermarket pisotns and rods.. just need somethig to resleeve and add them to.. i dont want to use mine.. i want one to be sent off
Old Oct 31, 2002 | 10:36 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: timing belt... what's the WORST that can HAPPEN????? (NonovUrbizniz)
Pretty much ALL Honda engines after they started using timing belts ARE interference engines. Especially your D16Z6. I have the same engine. Take off your t-belt and rotate the crank and see if it stops on a valve.
Old Oct 31, 2002 | 11:19 PM
KTeller8's Avatar
Default Re: timing belt... what's the WORST that can HAPPEN????? (Emerica)
https://honda-tech.com/zerothread?id=318481
he has a fourth gen accord dude.. with h22 swap i am sure
