how to remove upper intake mani on f23?
Old May 16, 2014 | 07:40 PM
KaliMist's Avatar
Default how to remove upper intake mani on f23?
Got an f23a1, i need like a guide or just some instructions on how to remove the upper intake manifold and clean the egr. I'm throwing a p0401 code which is insufficient flow. Looks like a bish :x
All help appreciated. thanks
Old May 16, 2014 | 07:55 PM
KaliMist's Avatar
Default Re: how to remove upper intake mani on f23?
Also, maybe a guide on cleaning the idle air control valve?
Old May 16, 2014 | 11:30 PM
NerfGunner420's Avatar
there are guides on that in the faq.
Old May 17, 2014 | 12:35 AM
MAD_MIKE's Avatar
MM Gruppe B
Yup FAQ covers F23. Remove upper plenum, clean EGR port, install new gasket, reinstall upper plenum.
Old May 17, 2014 | 06:54 PM
KaliMist's Avatar
I can't seem to find them. All guides with pics and actual info are 90-97, or the v6 6th gens.
I need the 4cyl f23 upper intake manifold removal to clean the egr port on it
Old May 17, 2014 | 09:19 PM
MAD_MIKE's Avatar
MM Gruppe B
Its the one that is not labeled with a year, as it has both 94-97 and 98-02. Look through the threads, not the titles.
Old May 19, 2014 | 10:58 AM
chrisnick's Avatar
Remove the throttle and cruise cables, 6 plenum bolts, the 2 on the egr valve, clean away! It's very simple.
Old May 19, 2014 | 01:55 PM
Single_cammer's Avatar
i have seen a buncnch of videos on you tube about this same problem theres a channel called eric the car guy he has a couple videos on this just look for that topic through his channel
arielb1
Apr 15, 2016 03:20 AM
David Smith
Sep 9, 2012 05:52 PM
silron
Honda Civic (2001 - 2005)
May 27, 2011 02:51 PM
prelude_93vtec
Jun 25, 2007 07:43 AM
361 accord
Mar 21, 2007 04:34 PM
