h22 running rich
Old May 16, 2014 | 06:44 PM
willfly's Avatar
Default h22 running rich
My hswap is running rich im not running o2 sensor which is probably why...but im runninga p30 ecu i just ordered a chipped p28 in which one of the setting. I requested. Was no,o2 sensor will that help eliminate my issue?
Old May 17, 2014 | 03:23 AM
holmesnmanny's Avatar
unless you plan on being wot all the time you need an oxygen sensor
Old May 20, 2014 | 07:14 AM
snobordboy's Avatar
Moderator
Default Re: h22 running rich
If you are running a basemap chip and no O2, it should be running rather rich, as the basemap is meant to be a safe map to get TO A TUNER. Get the car tuned right and it should be fine, with or without an O2.
Best scenario, get it tuned well for open loop, but have an O2 in and set for closed loop operation, for emissions, etc. Otherwise have blind faith in your tuner, or have the means to adjust your tune, and a wideband o2 in the car to monitor at all times.
jerryscherry
Engine Management and Tuning
Dec 24, 2010 04:13 PM
ATS*Mark
Apr 7, 2004 07:06 AM
ramz7887
Jul 19, 2003 10:48 AM
turbo Si
Mar 10, 2003 02:56 PM
