Car won't start with O2 Sensor Connected
Old May 15, 2014 | 06:08 PM
JasinC19's Avatar
Default Car won't start with O2 Sensor Connected
2000 civic si
Hi,
I currently have spark and fuel pressure.
Compression is also good as well as timing.
Before the car died I had a trouble code for o2 sensor.
I do find that the cat will stay when the o2 sensor is unplugged.
I do have 5v at tps sensor.
Can a short in the o2 circuit cause no injector pulse?
I'm having a hard time finding the test procedure for this issue.
Thanks
Old May 15, 2014 | 06:12 PM
Former User's Avatar
Default Re: Car won't start with O2 Sensor Connected
So replace the O2 sensor.
Old May 15, 2014 | 06:19 PM
NotARaCist's Avatar
I never narc'd on nobody!
Is it the secondary, or primary O2 sensor? Have you resistance tested the wires for the faulty O2 sensor? Have you tested your fuses?
Markadler47@gma
Mar 22, 2019 02:36 PM
cnumb
May 4, 2017 06:03 AM
