FS AEM Water methanol Injection Kit - Newer Model Kit
This kit was installed in a fully custom EG Civic that was dyno tuned to over 400whp. This car so no more than about 300 miles a year and the actual water-meth kit was used very briefly so everything is basically new. The car that it was in, is garage kept and only driven in summer months, if that matters. It was basically installed for bragging rights and props from the judges to back the high hp as well
Never been to drag strip, etc. so no extreme use.
Kit comes complete with everything you would get brand new (drill bit and tapping tool also included although not pictured). *** PLUS, I am also including the optional AEM filter and the on/off switch if you wish to bypass the unit. Instructions manuals included for the kit and the filter install as well. This is a "newer and updated" pump kit which has the 200 psi pump
LOWERED PRICE : $270 Shipped for everything. CONUS Only. HI, AK, PR, CANADA extra.
Never been to drag strip, etc. so no extreme use.Kit comes complete with everything you would get brand new (drill bit and tapping tool also included although not pictured). *** PLUS, I am also including the optional AEM filter and the on/off switch if you wish to bypass the unit. Instructions manuals included for the kit and the filter install as well. This is a "newer and updated" pump kit which has the 200 psi pump
