different offsets??
Old May 12, 2014 | 01:57 PM
shaggy37's Avatar
Default different offsets??
Long story short, busted a wheel at a construction site, bought a new one, bought the wrong one, turns out the offset makes it sit in more than the others. Looking at the others i noticed I dented the other wheel on the same side during the accident. I figured i could buy a new one with the different offset and run them up front. Would I be able to run two offsets of front and back? Or am i gonna need to buy a whole new two wheels so that they all match?
Old May 12, 2014 | 03:30 PM
toyomatt84's Avatar
Sanji
Default Re: different offsets??
As long as you don't rub the tire on parts of the body, running different offsets will make no difference on your car. Its actually quite common for people to run different widths/offsets on their cars. Heck, a ton of cars out there COME with two different sizes of wheel to begin with.
Old May 13, 2014 | 10:47 AM
shaggy37's Avatar
That's what I thought. Thank you. But I need to get an alignment. The goodyear i go to said they wouldn't be able to do it if i had the different widths. Do you think any other alignment place would be able to do it?
Old May 13, 2014 | 06:47 PM
toyomatt84's Avatar
Sanji
Any reputable alignment shop won't have a problem. If they did, Corvette's and S2000's would never get alignments.
Old May 20, 2014 | 08:02 PM
slowcivic2k's Avatar
A differential in offset front to rear in itself does not generate a problem, but if the wheel position SAI does not match the rim offset and width, tire scrub radius will be affected, which can cause dangerous conditions in the event of uneven suspension height (hitting a pothole), low tire pressure relative to the opposing side, or a complete blowout of a tire.
SAI: Point of intersection of the upper and lower suspension pivots (IE ball joints)
Scrub Radius: Point of intersection of the SAI and the wheel/tire centerline. Positive scrub is an intersection above the ground, zero scrub is where the tire centerline and SAI meet at the ground, and negative scrub is where the intersection occurs below the ground. Most FWD tuner cars use negative scrub and screw it up by putting offset wheels on, resulting in either zero or positive scrub, which is dangerous.
Vehicles equipped with different offset wheels front to rear cannot have tires rotated without dismounting the tire and placing it on the correct rim. Excessive offset inward/ or outward, will also create a mechanical advantage on the wheel bearings, overloading them simply by changing the offset, cornering will increase wheel bearing pressure, and induce failure.
To put it simply, offsets do not simply exist so you can fit a 255 tire on a Honda, they exist because different suspension geometries require them.
Old May 21, 2014 | 07:38 PM
toyomatt84's Avatar
Sanji
Okay, thank you for the long-winded response. I was only referring to the average user that comes into this forum, requesting information for their daily driver.
Old May 21, 2014 | 11:28 PM
You don't need to take it so hard, people need to have access to information regarding these types of changes, not simply copy-pasting what other people do because it worked for them. It is better to know the foundations before making these changes. Knowing that you can devise a solution that works for you, and your level of comfort (IE safety).
I don't post to gloat, I post to provide insight for the few of us that may search for a thread like this, and find good technical information.
Old May 22, 2014 | 07:21 PM
toyomatt84's Avatar
Sanji
You don't need to take it so hard.
You're misinterpreting my post. I wasn't being sarcastic. I was being genuine when thanking you for the in-depth article.
Too_Fast4u
23
Jan 19, 2009 06:23 AM
Tokyosmash!
Mar 27, 2008 11:21 AM
Mr.E.G.
18
Jun 19, 2007 07:57 AM
Boilermaker1
11
Sep 27, 2004 02:09 PM
Jake
14
Nov 20, 2003 09:17 AM
