Radiator fan on continuously
Old May 12, 2014 | 01:00 PM
swzen's Avatar
Default Radiator fan on continuously
I have a 2006 Honda Civic 2.2 CDTI. Recently the radiator fans have been coming on, continuously, as soon as I put the key in the ignition from cold.
I have changed the coolant temperature sensor as they're easy and cheap enough to replace but still the fans are coming on and also stay on for about 60 seconds after the car is switched off.
I'm trying to avoid taking it the garage and wondered if anyone knew what could be causing the fans to stay on continuously and if there was a way I could fix it myself.
Old May 12, 2014 | 05:37 PM
preludeNApower's Avatar
Default Re: Radiator fan on continuously
Check ALL fuses
Check to see if you can scan the car and read faults
Old May 13, 2014 | 08:10 PM
Honda_Dude84's Avatar
Did you try to check the relays as well? I have a 1997 Honda accord EX and the fan would stay on after the key was out of the ignition switch. I popped the hood felt the relay and it would click off then back on then back off and repeat this cycle. After I replaced the relay the problem stopped. Hope this helps
Last edited by Honda_Dude84; May 13, 2014 at 08:12 PM. Reason: Typographical discrepancy
therhett17
Aug 13, 2015 09:07 AM
Mr. M
20
Oct 16, 2013 02:24 AM
JH4DB858
Jan 10, 2012 07:32 PM
hunter349
10
Jul 1, 2009 06:02 PM
Sir^Ducer
Aug 1, 2006 02:15 AM
