GSR stroker
Old May 11, 2014 | 10:00 PM
Ekhonda24's Avatar
Default GSR stroker
I plan on buildin me a gsr stroker with my b20 interals and i wanted to know sumthin. I know i can use a ls/b20 crank in my gsr block and i wanted to know if i could use my b20 bearings and rods in my gsr block as well. Info would be much apreciated thanks
Old May 11, 2014 | 11:49 PM
hondaracing84's Avatar
Default Re: GSR stroker
Yes, you can use the ls/b20 rods and bearings. The rod bearings must be ls/b20 bearings. GSR bearings are different on the rods. The mains are the same regardless.
Thats my setup, gsr block with ls crank and eagle ls rods with ls bearings.
Old May 14, 2014 | 10:36 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
You will need to bend the oil squirters back on the bottom of the block if you use a 89mm crank. Or you can remove them entirely.
Old May 16, 2014 | 08:47 PM
Correct. Plug them with the golden eagle oil squirter plugs. That is what I did. It will also raise your oil pressure a little bit.
Old May 17, 2014 | 03:12 PM
jdragon1974's Avatar
^^^did the same on mine.Even if you think it clears when you manual spin it, they will clip off.
BMo Tuning
26
Mar 20, 2012 10:09 AM
dem0nk1d
Feb 4, 2007 01:32 PM
H23vtecEG
10
Jan 22, 2005 02:34 PM
Slick GS-R
Mar 30, 2004 08:03 PM
B18C_eg
Mar 17, 2003 08:36 AM
