Ported h22a OEM manifold on H23A (dyno inside)
Hey guys I just wanted to share some of the work I did on porting the oem manifold to squeeze some a little more power out of my stock motor H23A vtec.
Previous setup (blue line in dyno):
Stock JDM H23a vtec
Bosch Iridium Plugs
AEM V2 Intake
Professional Products 68 ITR throttle body
Rosko thermal TB gasket
Port matched TB port on manifold
Hondata Intake Manifold Gasket
Blacktrax unported spacer (8 holes to delete IAB)
PLM Tri-Y header
2.5" mandrel bent exhaust system
Magnaflow resonator and muffler
Chipped/Tuned OBD1 ecu
5sp manual
Changes made (red line in dyno):
*Ditched the AEM V2 since it was slightly smaller than the throttle body*
Custom Intake
BPi Flowstack/KN filter
8 holes ported in the manifold along with the blacktrax spacer
And finally heres the dyno comparison:
Both graphs are tuned. I believe there was some traction issue up top which caused the static. Same dyno, same tuner, different days.
It helped carry the power much higher into the power band, but for the most part, i picked up power nearly everywhere
And here is a baseline on OBD2 to now:
All tuning done by Kenny Sampson at Turbogixxer
Thank you
Stock JDM H23a vtec
Bosch Iridium Plugs
AEM V2 Intake
PLM Tri-Y header
5sp manual
Custom Intake
Thank you
Stingy Dyno!
Nice power increases, the curve looks good.
I think the exhaust is holding you back. Try going to a 3", I bet you pick up power at every RPM with as much as 10+ in some spots.
Picked up a custom header from a friend today as well. He didnt have any dynos on it so I will probably dyno this later in the summer to make sure it doesnt have any dips in power. Id like to use this header and merge it to a 3" exhaust but most likely the better header will stay.
Yea man, I wouldnt trust my car with anyone else
Yea thats most attributed to the much lower vtec engagement. The difference it made is absolutely incredible. About time for a traction bar
b18c5ej8
59
Apr 23, 2008 02:24 PM
precord96
20
Jan 14, 2007 06:22 PM
b19coupe
57
Sep 27, 2003 05:29 AM
