CRX Tuning/Mod questions
Old May 11, 2014 | 03:18 PM
NickH93's Avatar
Default CRX Tuning/Mod questions
Hey all. Kind of in a bit of a funk. Seems like the D15B2 is just hard to modify, so I have a few questions. (Sorry for my noobness, we all gotta start somewhere)
One, I planned on going turbo with my CRX, but tuning is a problem. I noticed the hondata units aren't compatible with OBD0 ECUs, so there goes that option. Are there any units like this that are compatible with OBD0? If not, what does an OBD1 conversion entail? Can I just get a comparable ECU and a conversion harness or will I need to swap wires around.
Also, any list of simple mods for the a d15b2 would be helpful. Thanks guys!
Old May 11, 2014 | 04:53 PM
br8crumb's Avatar
Default Re: CRX Tuning/Mod questions
O B D 1 will be ur best friend.. especially if going turbo. you can get away with using turbo edit or bre if doing n/a but i would feel much safer converting obd1 and safe tuning the turbo.
basically you can look at rywire, even ebay has cheap things that will get the job done but i wont vouch for any of them...
distributor + jumper, ecu + jumper, and injectors may or may not be needed
Old May 11, 2014 | 05:12 PM
NickH93's Avatar
Well I guess I should put that it is a dual point. (I know turboing dual points is a bad idea..) So, I guess I'd have to go MPFI to convert to OBD1?
Old May 11, 2014 | 05:35 PM
br8crumb's Avatar
hmmm.. good point. ill let some1 else chime in on that but i would assume yes
Old May 12, 2014 | 09:48 AM
ej1995's Avatar
Yes, you would have to convert to MPFI.
There aren't any modifications that will benefit your engine until it is atleast MPFI, so keep that in mind as you tread forward.
Old May 12, 2014 | 02:14 PM
NickH93's Avatar
Thanks. MPFI swap it is, then. Then I will worry about other mods. Problem solved.
schock3
Engine Management and Tuning
Jul 25, 2009 05:53 PM
browning
Feb 1, 2007 04:32 PM
blinger
Jan 25, 2007 09:16 AM
electric_rex
Sep 21, 2004 09:58 AM
