prelude 94 h22a swap
Old May 11, 2014 | 03:05 PM
georgen316's Avatar
Default prelude 94 h22a swap
I got it to fire and run today was idling great and my bro decided to play a prank and unhook the wire to the fuel pump to scare me. Well now the damn thing wont fire. Turns over fine checked fuses n nothing appears blown.. Help please n thx
94 lude type s swap h22a dohc vtec obd1. P13 ecu new wire harness from rywire.
Old May 22, 2014 | 02:52 PM
toivolaZACK's Avatar
Default Re: prelude 94 h22a swap
I would hit your bro in the head a few times with a rubber mallet. Was the car running when he did this? Like was it on?
I used to have a 1994 Prelude 2.3 DOHC non- VTEC man that car was fast and fun. Shame on him. Could just be the fuel pump relay, also called the main relay, you can bench test it by hooking some leads from your battery to the different pins and hearing if it clicks. Get a trusty Haynes manual to see how to do the test and for what results you should be getting. Only about 25 bucks for new Beck/Arnley relay thru RockAuto.com
HondaTechMan121
Jul 20, 2017 04:51 AM
Bryank930
Jul 15, 2011 01:51 PM
BOOstGhost
Aug 17, 2005 05:42 PM
