310cc saturated on p28 H23 vtec
I installed 310cc saturated after the previous 345cc peak & hold gone bad. Now my engine hesitates even when applying light acceleration, and misfires when i press more.
Is my engine running lean or there is a learning process for the ecu?... i did not touch the resistor box, do i need to cancel it?
I went with the 310cc coz i could not find the same size and type injectors.. also given that later models used 290cc saturated
Pls guide me, thanks
Those injectors will work like crap with a lower resistance. You have to remove the resistor box and run the saturated injectors with full power.
Saturated injectors with a resistor box will probably not burn up your ECU drivers. It's when you try and drive low impedance injectors with a stock ECU and no resistor box. That is when you will most likely end up burning up the drivers on the ECU.
http://www.hondata.com/techlowohminjectors.html
Ok. And as per my search, to remove the resistor box, I will simply unplug and solder the 4 red/blk wires + the yellow/blk wire altogether.
Looking forward to see the result. Thanks a lot!
Mike95lude
Jan 14, 2008 11:29 AM
MysteryWagon
Jun 15, 2005 09:35 PM
