H23A distributor problem
Old May 10, 2014 | 03:12 PM
Yannx13's Avatar
Default H23A distributor problem
I recently swapped a H23A DOHC Vtec in my '98 Prelude and and I have this dizzy wiring problem (I use the Bluetop Dizzy). I don't what the wires mean, like which is TDC, CKP, internal coil and etc 'cause I know the CKP and Internal coil is inside the dizzy... I run OBD1 ECU with conversion harness
Which wires mean what? And where do I plug them?
Old May 10, 2014 | 03:40 PM
holmesnmanny's Avatar
you should just use your original distributor and stay obd2
Old May 11, 2014 | 09:43 AM
Yannx13's Avatar
Default Re: H23A distributor problem
My engine harness is OBD2 and a bluetops CKP is read off in the dizzy, and it has internal coil. so i just can't put the original dizzy
civic-one
Jul 21, 2009 05:41 PM
bb6_00
Jan 26, 2009 09:45 PM
Haleiwa-Brando
Dec 26, 2007 09:45 PM
terribl3jon
Dec 3, 2005 02:09 PM
Eg6LazyPt
May 15, 2003 08:52 PM
