Gsr 24mm sway bar hits shift linkage on 99 hatch. Suggestions???
Old May 10, 2014 | 12:39 PM
Marvin1985's Avatar
Default Gsr 24mm sway bar hits shift linkage on 99 hatch. Suggestions???
Just like the title says. My car is a 99 civic hatch. The sway bar came from an 01 gsr teg. The shift linkage is from a B18 swap/motor that's in car now.
Old May 10, 2014 | 12:43 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: Gsr 24mm sway bar hits shift linkage on 99 hatch. Suggestions???
Integra linkage stay rods (the part that doesn't move) don't fit 96-00 civics all that well. I had to bend the linkage a little on my EM1 (ITR swap). Which part of the linkage is hitting?
Old May 10, 2014 | 12:46 PM
Marvin1985's Avatar
I'll upload a pic. The middle of the bar is hitting dead center over the linkage
Old May 10, 2014 | 12:53 PM
Marvin1985's Avatar
Here's the hitting spot
I also have the end links that are at a 90* to the ground
Old May 10, 2014 | 01:09 PM
Marvin1985's Avatar
I think the end link goes the other way
Old May 10, 2014 | 08:07 PM
B serious's Avatar
Nope, the endlink is fine. Just bend the shift stabilizer a little. Looks like it's already bent in other places.
Old May 11, 2014 | 10:25 AM
Marvin1985's Avatar
After looking online I got it to fit fine by inverting the links. The linkage isn't bent btw just the pic looks wierd
Old May 11, 2014 | 01:11 PM
tony_2018's Avatar
Fish Twig
I find that strange. I never had a problem with a shift linkage used from an integra. The EM1 subframe isn't all that different the EJ subframe.
Old May 11, 2014 | 06:15 PM
tony_2018's Avatar
Fish Twig
Also is it hitting it when you shift, give it gas? How are your motor mounts? Do you have everything bolted onto the T bracket?
Old May 11, 2014 | 10:15 PM
98civdx's Avatar
Master Detailer
Tony, it's not the linkage, it's the sway bar.
DC sway bars are known not to fit 96-00's very well at all.
dungeonKing
Feb 9, 2009 11:31 AM
PhoBichNga
Jun 21, 2002 11:37 PM
karmannghia
Nov 18, 2001 06:24 PM
