bushing overhaul 90 accord
Old May 9, 2014 | 05:44 AM
bdmlilburn's Avatar
Default bushing overhaul 90 accord
1990 honda accord ex sedan manual
ok i have been scouring the internet and these forums for about an hour now trying to track down some radius rod bushings. i was really looking for a set that came with new shims and locking nuts but alas i cant seem to find these things anywhere. i was able to find the energy suspension master kit located here:
Amazon.com: Energy Suspension (16-18108R) Polyurethane Master Set Bushings - Red: Automotive Amazon.com: Energy Suspension (16-18108R) Polyurethane Master Set Bushings - Red: Automotive
it says it covers all critical bushings and mount locations. this may be slight overkill for my needs though. it says it doesnt come with sway bar bushings and i know my end links are cracked. my main concern is the radius rod bushings though and it would be nice to have the lower control arm bushings to go as well.
Is there a kit online that sells the radius rod bushings with shims/spacers etc? are they called something else as well?
Old May 9, 2014 | 01:34 PM
holmesnmanny's Avatar
rock auto has the moog kit but i believe it only has the bushings ..you would use your existing washers but if you want the caster washers to use for caster alignment purposes you would look at the "caster" tab and it will show caster shims for sale
CoastalSi
Jun 5, 2010 10:30 AM
19Accord97
Jul 16, 2009 08:57 PM
99teggsr
Sep 11, 2005 11:11 PM
Racermech
Jan 31, 2005 05:30 AM
Burke
Dec 16, 2003 09:42 AM
